heads/cam/timing chain install
hey guys I need advice on how to line everything up. The timing chain cam sproket came off the cam because the bolts snapped,( Im gonna use APR bolts) So i have new cam/ timing chain set with sprokets and new heads. I have spun the crank around alot. So its not where it left off, how do i line up the cam and the crank so when the chain/sproket goes on its all lined up.
thanks alot guys
thanks alot guys
Re: heads/cam/timing chain install
The info in this link will tell you how.
4th Gen LT1 F-body Cam Install
You really should have had a good reference on hand before starting this project.
Sergio
Jan 27, 2016 04:27 PM
