ARP head bolts or studs? which would you do?
Old Feb 1, 2012 | 05:15 PM
dizwiz24's Avatar
Im putting AFR 210cc heads onto my supercharged stock bottom end 93 corvette. I will be using the larger cc of these heads to reduce the compression ratio of the car from 10.25:1 to app. 9.4:1.
It will also have a 224/232 114LSA blower cam, 1 3/4" long tube headers.
I anticipate making 525 rwhp w/ these combo at 10 psi boost.
I see there are 2 ARP kits for head bolts:
134-3701...listed as head bolts
$81.04 thru summit racing
ARP 134-3701 - ARP High Performance Series Cylinder Head Bolt Kits - Overview - SummitRacing.com
234-4301...listed as stud kit
$215.46...though the picture doesnt appear to show all the parts..Im assuming there is more in that kit.
ARP 234-4301 - ARP Pro Series Cylinder Head Stud Kits - Overview - SummitRacing.com
Which ones would you use? This isnt intended as a max-effort build (Im still on stock bottom end), simply an intermediate build to tide me over for a few years until I build a real monster.
Old Feb 1, 2012 | 05:32 PM
Bersaglieri's Avatar
Re: ARP head bolts or studs? which would you do?
I think you'll have other parts pop before the head bolts would. ARP Hi-Perf head bolts should hold fine. Note there is also the Pro Series.
-Dustin-
Old Feb 3, 2012 | 06:49 PM
Z28SORR's Avatar
Always liked studs. Especailly on a blown app.
Old Feb 13, 2012 | 11:34 AM
Masnart39's Avatar
The bolts will work fine at that level of boost. Over 15psi, I would probably use studs.
maybe2fast
Mar 16, 2015 09:45 AM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Catmaigne
Dec 25, 2014 12:16 PM
thenewkid
Nov 27, 2014 09:41 AM
