tell me about forged cranks for the lt1....
Old Dec 26, 2011 | 05:44 PM
dizwiz24's Avatar
Ok,
Im planning on rebuilding my lt1 into a 383.
Im going to do the bottom end work first and then, after I have recovered financially from building that, Im going to put on expensive aftermarket heavily ported heads. I will re-use my mildly ported stock lt1 heads until I do that.
I will also be re-using my p600b blower (at first), and then looking to put something bigger on there (like a vortech ysi).
I like my plan because I can run a little bit higher compression and less boost w the p600b, then I'll be sure to get a bigger cc head (to lower the CR) and run more boost with the new head/ blower swap.
My question now is on forged cranks. I have a corvette 4 bolt main lt1 block right now (stock bottom end).
My lt1 stroker crank options seem to be:
Eagle forged crank (cheapest, many seem to use that here)
Callies Dragon Slayer
Callies Magnum (expensive).
My eventual goals are a 700+ rwhp car. Id like to be able to spin this thing to 7000 rpm and make that kind of crazy power.
What crank should I be looking at?
BTW, anybody know what the stock crank can withstand ? (have their been any crank failures here? )
Old Dec 26, 2011 | 07:43 PM
Kevin Blown 95 TA's Avatar
Re: tell me about forged cranks for the lt1....
Stock crank is good, but out of the choices you posted I would use the Dragon Slayer.
Old Dec 27, 2011 | 07:54 PM
onefastmx5's Avatar
I would trust the stock crank to hold up to 500hp easy, but I'd get nervous passing 600hp and knowing its going to stay reliable with a heavy foot. The Dragon slayer is a good choice if you have the coin for it. I personally went with the eagle forged (just ordered yesterday) because I'm on a low budget for my 385, but I'm sure it will do fine with my v1 + spray.
Old Dec 29, 2011 | 10:47 PM
MachinistOne's Avatar
If you have the coin, I would use the Dragonslayer, but as a cheaper option I would choose a Callies Compstar over the Eagle every single time.
Old Dec 29, 2011 | 11:32 PM
tt383lt1's Avatar
i use a callis any day. i got the steath and im very happy its better then the dragon slayer but callis makes the best stuff. i think the steath is now called magum
truthmatters
3rd Gen / L98 Engine Tech
Aug 19, 2015 04:09 PM
4586
Aug 18, 2015 07:08 AM
karpetcm
Aug 14, 2015 03:02 PM
Catmaigne
Jul 14, 2015 05:17 PM
