stroker kit advice
Old Jan 29, 2012 | 09:07 AM
shawngamblez28's Avatar
stroker kit advice
looking at buy a stroker kit for my lt1 what 1 do u guys recommend scat ,eagle,ect..... just want 2 make sure i buy quality kit thanks
Old Jan 29, 2012 | 09:10 AM
Re: stroker kit advice
Need a lot more info - what displacement, what power level, what max RPM, will a power adder be used, etc.?
Old Jan 29, 2012 | 09:31 AM
94 lt1 .30 over 6.0 rods 3.75 stroke compression around 11.5-12to1 area 7500-8000 rpm max looking for 700hp on motor an shooting a 250 shot on top of it.my heads an intake r going 2 advance inductions get n the 200cc head job done street/strip intake job.cam im not sure on yet.ive got a 4000stall turbo 400 w/trans brake in the car already ford 9inch spool 4.11 gears.i want a 10 flat street car on motor. im at 11.70 with a 125 shot with a lil weight reduction an alot of other changes .
Old Jan 29, 2012 | 09:44 AM
96capricemgr's Avatar
You need to rework your thought process a whole hell of a lot.
IMO Advanced Induction is the company to work with when you have lofty goals but IMO your goals are pipe dreams more than goals.
Then it is laughable that with a goal like this you want to use chinese rotating assembly and GM casting heads and intake. 10.0 on motor with nitrous gearing/converter is going to present another challenge.
I would honestly say spend at least another year researching things before you buy anything.
Old Jan 29, 2012 | 09:48 AM
Kevin Blown 95 TA's Avatar
So you're going to build a solid roller 383 that turns 8 grand making 950 hp on 200cc LT1 heads and a stock intake manifold and you are considering a chinese crank kit? Does that about sum it up? Have you really thought any of this out?
Old Jan 29, 2012 | 10:07 AM
Is that "700hp" at the flywheel, or at the rear wheels? .... on straight motor?
Old Jan 29, 2012 | 10:27 AM
Fred, does it matter?
700flywheel NA on a motor built to handle 250shot with stock casting heads and intake is a stretch anyway.
To actually make a reasonable attempt at this he needs to be looking at aftermarket heads, single plane intake would be a good idea, the solid roller valvetrain for the street is going to cost nearly what he is looking to spend on the heads and rotating assembly combined. The cost to step up to an American crank will be a drop in the bucket compared to the rest of the build.
By the time he is done with actually adding up what it will take to pull this together(car included) I bet he chokes on the price because IMO $20K would be enough to get started but NOT finish this project. I never attempted to even do a full engine build but IMO $25K wont finish this project.
Old Jan 29, 2012 | 10:51 AM
I'm just trying to see how far out of touch with reality he is. If he's serious, he should be looking at a setup similar to N2ODave's SB2.2 head monster. I'm sure Dave would be glad to fill him in on the ultimate cost.
396 ci LT1 block with billet 4 bolt caps filled to the freeze plugs with block filler.
Callies Magnum crank
Oliver billet 5.85" rods
Diamond SB2.2 13.5-1 pistons with offset pins, nitrous ring package, friction coated skirts
Cam Motion solid roller for SB2 with a 4-7 swap 270/280 @ .050 .690/.710 113 lsa
Isky Red Zone offset lifters
Smith Bros pushrods
GM SB2 heads converted to reverse cooling, 287cc runners, 48cc chambers, 379 cfm I / 260 cfm E @ .700, 304 cfm I @ .400
Del West Ti valves 2.15/1.65
T&D shaft rockers, 1.8 I / 1.7 E
Accel Gen 7 dfi, Accel dfi distributor, 83lb injectors
SB2 resrictor plate intake, Accufab 2200 cfm throttle body
Lemons headers 2" primary / 4" collector
Spintech dual 4" oval with Spintech 4" oval shootout mufflers countersunk into custom pockets in the floor under the seats. Turndowns
Motor makes 740 @ 7900 and 520 lbft @ 5200 on the engine dyno.
Interesting thing is the build seems to have started in 2005, and never seems to have actually been totally completed, although maybe Dave just never came back to the site.
https://www.camaroz28.com/forums/adv...gether-369194/
https://www.camaroz28.com/forums/adv...ss-sb2-382538/
https://www.camaroz28.com/forums/adv...-lives-456716/
https://www.camaroz28.com/forums/adv...direct-420169/
Old Jan 29, 2012 | 02:36 PM
Dave Norquest "N20Dave" 9.98 @ 137 1.47 60' naturally aspirated, manual trans 396 SB2.2headed LT1 SR 28x10.5W's 3730lb raceweight.
I didn't find any bottle track numbers, did see references to 740flywheel HP 626 RWHP on motor, 853 RWHP on a 200 shot.
Here is a quote from the owner.
Secondly, let me just express a word of caution to those of you thinking of doing this. Most of the front of the car had to re-configured to make this work. We spent alomost $20,000 on this motor. Nothing will go as planned and everything is custom. Not trying to discourage anyone from trying this. I'm just saying if I knew then what I know now I would have thought twice about it.
Now his using SB2.2 heads made a lot of things more expensive but at the same time probably helped make the power number easier to hit.
A friend own the red '67 Chevelle featured in I believe it was the January HotRod magazine. I bring it up because it is 730hp 402ci gen 1 motor that turns 8500 and goes 9.9 in a 3700lbs car, so it is in the ballpark of what you are asking about and still 23degree. I don't think he has even totaled up the complete cost but we I know enough about it to say $20K wont built that engine much less the car.
Annual maintenance on something like that in the form of springs and rebuilding the custom made shaft mounts and tool steel lifters is probably $1500+. It would not need that kind of maintenance if it were a track car but he genuinely does drive it on the street.
Old Jan 29, 2012 | 08:56 PM
GreasyB's Avatar
I'm not sure how deep your wallet is, but those are some outragous goals in my opinion for most people.
Old Jan 30, 2012 | 06:42 PM
i didnt say i wanted a chinese stroker kit thats why im asking u guys that have already done it so i know im buying a good kit.an further more i am aware this **** isnt cheap an i dont think theyre pipe dreams cause i have seen on this site quite a few cars running mid 10's with similar set ups hyd rollers yet to boot.i am running 11.73 at 118 with a stock headed lt1 with110,000 miles on it now.check out my garage see my list of mods .if u want i can send u video's to prove the car runs that.
Old Jan 30, 2012 | 07:43 PM
WS6T3RROR's Avatar
Start by finding the other 0.5s that your current setup is missing.
Skip the stroker, put new rods and slugs in it, add a good fuel system, and strap on a D1SC with a cam to match. It will be a whole lot cheaper in the end than N/A with dope. As a bonus it wont suck to drive (well as close as an A3 can get to not sucking).
It does not take anywhere near 700hp to run 10.0, you just have to know how to make the car work and it can't be a pig.
Old Jan 30, 2012 | 11:05 PM
DirtyDaveW's Avatar
I think when you started off referencing the Scat/Eagle brands, then you're implying "Chinese stroker" parts. Best of luck to you on your quest to get those numbers N/A. Anything that can pull those numbers N/A will need quite a bit of maintenance and frequent inspections I would believe. The cash infusion that the guys are mentioning are staggering enough to me. I thought my turbo build was high but it's pocket change compared to those prices.
Old Jan 30, 2012 | 11:23 PM
I seriously doubt there are many (if any) people here who are making 700HP on straight motor. That is a monster build, and to expect someone to recommend a "stroker kit" without even telling us the magnitude of the project was really pointless. No one has questioned your current build or it's performance.... only your seeming innocence on the magnitude of your plans.
Old Jan 31, 2012 | 03:01 AM
i just figured if i was running the numbers i am now on pretty much stock motor i didnt think it was going to take that much more to go 1.8 sec faster hahaha.i found a callies dragon slayer crank an oliver rods an some diamond nitrous piston that will handle a 250 shot.i ordered it.I figured on 15k-20k just in the motor.thanks for ur guys advice
