Ignition Question - 97 LT1
Old Apr 16, 2003 | 11:46 AM
Brettinator's Avatar
Sitting in the carwash my SES light starts blinking then goes solid car starts idling a little rough. I checked and cleared the code P0300 misfire, etc. I have the vented OPTI and am curious if it could have just had moisture fog up the opticals or could it be wires and plugs needing replacement? It runs just fine right now with no SES. I'm installing MSD or Taylor wires and NGKTR55 plugs & new cap/rotor (OTPI @ 69K miles should be fine) in about a month after I install long tube headers. But I'm curious as to whether or not the wires could be faulty and need replacing now? or if it's just the OPTI got a little moister in it from the car wash?
Old Apr 16, 2003 | 11:53 AM
MEAN LT1's Avatar
Re: Ignition Question - 97 LT1
Most likely, water got into your opti, Id be very carfull of going through the car. Usually the opti is not very forgiving when water gets in it. You should be fine for now.
Old Apr 16, 2003 | 12:27 PM
James Krawcion's Avatar
There's a million things that can make them throw that code. If it happened right when you went through the carwash, I'd bet that your cap got wet. The optis have a horrible seal between the cap, middle piece & rotor itself. They tend to loosen up &/ or deteriorate. Personally I've seen a few that have loosened within a month after installation, mine included. If you're going to take it off anyway checking out the opti would be a gould idea. Make sure there's no rust on the degree wheel itself inside the rotor. The sensor itself is like a CD lens so treat it as such. New caps come with new seals. I'd recommend using them.
Chris'SS #2152's Avatar
I wouldn't go thru a car wash with a Opti that's on it's way out. After a couple more time with water say bye bye..
Mine when out driving in the rain.....
Old Apr 16, 2003 | 01:17 PM
do you think this qualifies mine as "going out"? I guess if it is I might as well change it. Wonder how much they cost? They don't sound cheap
Old Apr 17, 2003 | 12:19 PM
97 SLP Company Car's Avatar
cap and rotor
Does anyone have a picture of the cap and rotor for a opti, only asking because I havent seen one taken apart.
Old Apr 17, 2003 | 01:48 PM
Re: cap and rotor
http://www.charm.net/~mchaney/optisprk/optisprk.htm
Old Apr 17, 2003 | 02:03 PM
Re: Re: cap and rotor
Old Apr 18, 2003 | 11:37 AM
SWEET! Awesome pictures,the only way I could get a better view would be if I was standing right there while it was done. Thanks
Old Apr 18, 2003 | 01:48 PM
bachehbad's Avatar
So you guys are saying just washing your car is bad for theopti?!?
damn i wash my car like every other day!!! with the hood closed how does water get on the opti?!??
Old Apr 18, 2003 | 01:52 PM
Phil at Dynatech http://www.dynotech-eng.com/dynaspark.htm told me that a certain amount can sometimes splash under the car and get the opti wet but that in my case it could be old boots/wires/maybe burnt through but that it is still possible the OPTI got wet even vented like mine....shrugs...
cmdeshon
Dec 27, 2014 10:06 AM
Ari G
Dec 11, 2014 03:21 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
lbrowne
Nov 13, 2011 04:25 PM
Jul 4, 2005 05:00 PM
