Fuel Pressure low
Old Apr 17, 2003 | 06:25 PM
hosspwr94's Avatar
Unhappy Fuel Pressure low
I just recently installed a new Walbro High pressure fuel pump with an Accel Adj. regulator and some new SVO 30# Injectors.
My question is that when I turn the key on I pressure up to almost 30psi and then it drops to almost 10 PSI. and when the engine is idling the pressue is around 25-30psi.
I do know that the LT1 is supposed to be around 41-47psi at key on.
Are there any ideas that somone might have that could help solve this problem?
I also installed the updated opti with the new vacuum harness could someone give me a rundown on where the two connections go up top. Just so I know that I got them right!
Old Apr 17, 2003 | 06:49 PM
hosspwr94's Avatar
Help please!!
Surely somone has some ideas!!
Old Apr 17, 2003 | 07:31 PM
Doesn't much sound like a high pressure pump, does it? I guess you have replaced the fuel filter? Have you tried adjustments with your regulator?
There are pics of the opti vent connections on my Tech Page.
Old Apr 17, 2003 | 07:47 PM
hosspwr94's Avatar
I have tried adjusting the regulator, it doesn't move it!
Thanks for the link!
Old Apr 17, 2003 | 07:53 PM
hosspwr94's Avatar
can the opti manifold vent go under the throttle body instead of where the PCV valve connects?
Old Apr 17, 2003 | 08:55 PM
hosspwr94's Avatar
More Input please
still need some help
Old Apr 17, 2003 | 09:30 PM
Is there a special reason you would want it there? I guess it would work as long as that vacuum port provides the same vacuum as the one on the side of the manifold.
Old Apr 17, 2003 | 09:33 PM
hosspwr94's Avatar
That is where I originally placed it, and was wondering if it could be a vacuum problem for the engine.
I tried moving it to the other location and put the plug in the front under the T.B. but there was no difference.
Old Oct 10, 2003 | 07:29 PM
hosspwr94's Avatar
not the problem...
My problem ended up being that I had a loose connection at the pump inside the tank! Hope you cut a hole over the tank through the hatch area
Originally posted by DarkKnight
Dude, thats strange. I just put up a post about the exact same thing! I have the same pump and an Aeromotive AFPR. no matter which way I turn it it stays at 30psi. This just started...
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Alex Barnes
Jan 24, 2015 10:21 PM
IDOXLR8
Aug 6, 2002 12:30 PM
