Drive shaft
Drive shaft
My drive shaft by the trany tail will come up and hit the floor board when i realy floor it... it dident do this befor and i cant find anything broke u can see the mark it made when ur under the car...... any one no what causes this
could be a broken motor mount. the rubber could be pulling away from the metal plates but looks intact when looking at it. put the car up on ramps and put a jack under the tail shaft, or tranny pan(use a peice of wood or something to distribute the force so you don't cruch the pan) and jack up the tranny a bit and you will be able to see if the mount is any good. if not it is easy enough to replace it and only about $20.
same prob with mine, blew the trans mount twice, change in 25 minutes, save the hassle of getting under there twice and buy a poly mount 20$
www.streetlethalperformance.com
taner
Sep 9, 2002 11:36 PM
