how can I get to the radiator reservoir tank?
Old Apr 16, 2003 | 12:22 PM
blak96SS's Avatar
This may be a dumb question, but upon first look, it doesnt look very easy to get to the reservoir tank. I am trying to track down where I am losing coolant from, and I think it may be the culprit. Anybody know an easy way to do this?? TIA
Old Apr 16, 2003 | 12:44 PM
Atilla_95_Z28's Avatar
From: As close to Kentucky as I can get and not actually live there!
Take out the battery. It is right underneath of the battery holder. I had the same prob. The alluminum pipe running from the radiator to the resivoir had a tiny -little -itty -bitty crack in it. Cost about 15$ to repair it.
Old Apr 16, 2003 | 01:12 PM
blak96SS's Avatar
ok, so there is a piece on the back of the battery that holds it in place...how do I get to that screw to remove the battery? I have it disconnected already...I cant get down into that space to loosen it..
Old Apr 16, 2003 | 01:35 PM
matt diamond's Avatar
use a long socket extension
Old Apr 16, 2003 | 01:51 PM
blak96SS's Avatar
after i pulled the battery out, I can see coolant on the battery tray and I know that the coolant is leaking from somewhere on the passenger side area. There is also coolant inside the passenger wheel well, so i figured it was probably coming from the reservoir. I pulled it out and filled it up and it doesnt appear to be leaking from anywhere, but it was completely empty when I pulled it out. Where else could the coolant be leaking from??
Old Apr 16, 2003 | 02:17 PM
hairbear21's Avatar
Check the aluminum tube like Atilla said, it may be a hairline fracture and be causing the leak
IndyZman
Oct 22, 2015 02:17 PM
68camaroboltz
Oct 5, 2015 01:46 PM
KYWes
Sep 26, 2015 08:49 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
Pwilson59
Sep 3, 2015 08:47 PM
