how to remove fuel from the tank?
Old Apr 16, 2003 | 07:32 PM
tanker's Avatar
Hi,
I got my engine running, and now I am working on the fuel pump. I already dropped the rear end. The problem is that I have full tank of gas, and I cannot run my car for long time yet, don't have alternator hooked up. Maybe anyone knows a way to drain the gas tank. I tried sticking a hose in the tank, but it didn't go in.
Thanks,
Tomas
Old Apr 16, 2003 | 07:48 PM
Z28ROC's Avatar
There's a fuel pump test wire located on the passenger side fender somewhere. I think it's red. All you do is diconnect the fuel line at the filter, put 12v on the wire and drain into container.
I've never looked for the wire. But I think I heard in was all by itself.
Shoebox?
Old Apr 16, 2003 | 07:52 PM
There is a pic of the prime connector on my Tech Page. It is grey on the 1995. If the pump still works you could disc the filter and pump the contents into a container.
Old Apr 16, 2003 | 08:31 PM
tanker's Avatar
reply
Yes, the pump still works, and I will just try draining the fuel by disconnecting the fuel filter.
Thanks a lot,
Tomas
Old Apr 16, 2003 | 10:04 PM
m0nk's Avatar
I changed my gastank without removing the rear end, you just gota disconnect one end of the the panhard bar and then remove the upper panhard mount brace thingy
Old Apr 17, 2003 | 09:19 AM
White Z 4 Show's Avatar
trey beat me to it. disconnect your filter and run a hot wire to your fuel pump. I just replaced my filter the other day and I leaked a little gas out but I did a pretty good job (hahaha, I mean GOD that is a hard job to do and all)
DirtyDaveW
Dec 1, 2016 05:37 PM
Deadbolt24
Jan 19, 2015 01:29 PM
ANDYZ28
Dec 29, 2014 09:13 PM
guionM
9
Aug 29, 2002 01:48 PM
