Quick Dumb Question.......
Old Apr 17, 2003 | 09:22 AM
veryslowfbody's Avatar
OK I have only 2 bolts holding my camshaft timing chain sprocket on. There are supposed to be three but one was bad stripped and broken so i just put two in with thread locker.
How much time do you think i have before the car blows up
Old Apr 17, 2003 | 09:40 AM
Gripenfelter's Avatar
Might come loose after 40K miles.
Might be less.
Depends on your driving habits.
Chrisbequick's Avatar
About 35 seconds. Run!!
-Chris
Old Apr 17, 2003 | 12:35 PM
Unhappy
It has been running for about 2 weeks now without any problems.
I am a terrible mechanic and did want to go through the trouble of rethreading it and removing the broken screw. I tryed to remove the broken screw but i drill in crooked and bombed the threads.
ARE you sure it will fly apart in less than 40k???
If so i think it is a good time to sell the piece that has given me nothing but problems that i barely had enough money to replace.
The last person that had it before me did not tighten the bolts on the Camshaft timing sprocket tight enough and without thread locker..... (All the bolts were loose and one broke from torsional strain). I was glad to find my loud metallic knocking noise that i thought was a lifter. I bought new grade 5 bolts.
What do you guys think??
IndyZman
Oct 22, 2015 02:17 PM
WobblySausage
Oct 7, 2015 02:44 PM
68camaroboltz
Oct 5, 2015 11:56 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
NewsBot
Sep 14, 2015 09:20 AM
