need advice on putting my new AC compressor on
Old Apr 16, 2003 | 06:51 PM
weaponZ's Avatar
i got a new ac compressor and condensor to go on with the rest of my stuff.should i hook the lines up and bring it to get cleaned out or should i leave it unhooked and get the lines cleaned out first?thanks
Old Apr 18, 2003 | 11:06 PM
weaponZ's Avatar
ttt
Old Apr 18, 2003 | 11:15 PM
I would make sure all your fittings are clean, put it together and then take it to have it professionally evacuated and recharged. Don't operate the compressor before you have it charged! Pull the fuse or the relay for safety (but don't forget you did so).
Old Apr 19, 2003 | 07:57 AM
weaponZ's Avatar
so if i have trash in the lines,i can still connect them to the compressor and the evacuated process will take it out.i did have all the freon removed with the machine that charges and removes freon when we found out my compressor had locked up.
thanks for the help shoebox
Old Apr 19, 2003 | 08:13 AM
94SLUG's Avatar
AC works on pressure if you have no gas in the system the compressor wont work. Do you have the old compressor off. Put a new orphous tube and a new dryer. New o rings and flush system, I use break cleaner and air to blow it threw the system(i use this method on every car). Your lines are fine unless they leak. AC is so easy to do when you understand how it works. Dont forget to use compressor oil and all the o rings. The evac process will not clean the lines only removes the gas. You must flush.
I just did all the above my ac reads 48dgr it will be nice this summer.
Old Apr 19, 2003 | 08:28 AM
weaponZ's Avatar
summer.
new orphous tube and a new dryer.does a local parts store carry this?the old compressor is off the.thanks for the flush idea.i will do that today.so basically just flush it out real good,go get those other parts and go get it charged?
Old Apr 19, 2003 | 09:05 AM
"orphous"?
Would that be "orifice"?
If the lines have been exposed and not covered while the system was open, then yes, I would do something to flush them out.
Obviously the system works on pressure. There are pressure switches that are designed to keep the compressor from running when the charge is not adequate. My suggestion was merely as a safety measure in case the others failed.
Old Apr 19, 2003 | 09:07 AM
94SLUG's Avatar
I would suggest using some UV oil in the oil that way if it leaks its real easy to find. Yes local auto store should have dryer orphous tube. Not i sure i spelt orphous right but you get the point. Dryer is like 35-45bucks the o-tube is cheap also. I dont have a scale to put the gas in with so, i use High/Low pressur gauges. This is not the correct way but does work.
You should have some nice AC.
Old Apr 19, 2003 | 09:11 AM
94SLUG's Avatar
[QUOTE]Originally posted by shoebox
[B]"orphous"?
LOL i even asked my buddy how to spell ORIFICE. Not trying to tell ya your wrong shoe just that its not needed
Old May 7, 2003 | 12:49 AM
craigffb's Avatar
Where is the orifice tube at on the system. I'll be doing mine real soon and I need to get all the parts, and how much are we talking for that?
Old May 7, 2003 | 02:27 PM
craigffb's Avatar
I called Jason at Sam Taylor Buick to get the seals and a new dryer and he told me that the F-Body systems dosen't have an orifice tube. Is he right? If not where is it at?
Old May 7, 2003 | 05:52 PM
I think Jason is correct. I have not found an orifice tube in the parts book.
Old May 7, 2003 | 08:18 PM
craigffb's Avatar
Thanks Rob,
I should start e-mailing you direct.
Old May 8, 2003 | 01:17 AM
Lt1t56's Avatar
No orifice tube on our systems, use of the expansion valve eliminates the need for one.
Old May 8, 2003 | 02:02 AM
craigffb's Avatar
OK, I got all the parts ordered that I need. Any tips on getting the old compressor out and the new one in?
