How can I calculate what spring height I need for my new cam?
Old Apr 17, 2003 | 08:03 PM
BrianZ28's Avatar
I bought a bigger cam for my car, and the valve springs are mashing flat. The install height is 1.885, the cam is 654in, 652ex. 254in, 260ex. Is there a formula to calculate what spring install height that I need?
Old Apr 18, 2003 | 08:47 AM
arnie's Avatar
Not really a formula, just simple math really. You need a spring that has enuf travel plus and additional minimum .05-.06" 'cushion from coil bind. I like to work backwards. For instance, as an example:
A spring has a 'coil bind' dimension of 1.150". Take your lift, (.650") add the .05" cushion to get .700". Add this to the coil bind dimension you get a necessary (for that spring) installed hgt. (minimum) of 1.850. Now ask yourself, does that spring give adequate seat pressure installed at 1.850" to determine if the spring with those specs is usable for your application. Working from the installed hgt. side of things, does little cuz it does not include the coil bind dimension, which is the important limiting criteria to anchor from.
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
grabbem88
Feb 22, 2015 11:16 AM
cmdeshon
Dec 12, 2014 10:51 PM
