Car wont start
Old Apr 17, 2003 | 09:47 PM
1994CamaroZ28's Avatar
Car wont start
Okay heres the story my oil sender went out so i replaced it plug broke so im gonna have to get another one. second possibility is that there was wires under the steering wheel were a old alarm system used to be and i cut and taped them, gets power just wont try to start.
Old Apr 17, 2003 | 09:57 PM
AFast83z28's Avatar
Same problem, different solution?
I had nearly the same problem on my 1990 rs v-6. The guy that had it before me installed an alarm. He had put a different ignition in and left the stock VATS ignition installed but put it by the alarm. Some how the two wires to the ignition got cut and it wouldn't crank for crap. It would turn over with full power. However no cranking. I taped the two back together and wah-lah! That could be it if you have a different ignition. They are VERY VERY SMALL white and orange wires running into a connector on my car. Hope this helps.
James
Old Apr 18, 2003 | 12:50 AM
My brother looked something up something about having to reset a vax control or something make any sence to anyone?
Old Apr 18, 2003 | 09:40 AM
AFast83z28's Avatar
resetting? I have enver heard of that but I am not a genius. All I know is that if you stick the wrong key in there and try to crank it wont crank. It has to be the key you got originally unless you have changed out ignitions. If you do that you still need to keep the old ignition I believe hidden somewhere. Maybe someone else can help.
James
Noenav
Mar 1, 2019 07:38 AM
97SSdude
Dec 31, 2014 07:43 PM
tds1213
Nov 27, 2014 12:55 PM
USAirman93
Nov 24, 2014 03:37 PM
Dave19yz28
Jan 26, 2003 01:45 PM
