HELP 95+ opti harness into main elec. harness problem????
i just put a tread in with the wrong info..oops, but anyways the connector from the new vented opti that goes into the main electric harness on my 94 is different, how to we need to fix this, do you just splice everything together or is there something else i need to pick up??? any help is again appreciated, i'm getting desperate, i go on vacation sunday and want the car. thanks again
tim
tim
There is a little pigtail harness that you need to pick up to plug the 95+ opti into the 94 and older harness. Jason Cromer sold me one when I bought my conversion kit from him. Hopefully someone will chime in with the part number since I have no clue what it is.
Guess I was not explicit enough in my answer to your previous post. You need a new harness Part #12130319. It is a pricey item.
You may have to make a notch in one side of the connector at the intake end to make it fit.
stockssn2o
May 25, 2015 08:54 AM
IgorT.455/406
Mar 12, 2015 03:39 AM
