CMMG style exhaust question
Old Apr 17, 2003 | 10:28 AM
RedWolf's Avatar
GMMG style exhaust question
I just bought (2) S.S. 30" long tube 3" chambered mufflers from Summit. I wanted to bring them to meineke and have them custom make the exhaust to look like the GMMG. But as i am thinking about it, maybe i can just have them custom make the exhaust and have them put a y-pipe and the 2 mufflers behind the Cat and make it look like true dual out the back. Hope this made sense. I dont think it matters either way. just looking for opinions. All i know is it should sound the same as the CMMG but for half the price. thanks
Old Apr 17, 2003 | 11:56 AM
Dr.Mudge's Avatar
2x 30" mufflers are not going to fit before the stock CAT/CATs location, which means moving the heat shield yada yada, not worth it. Find a place to stick them that wont have you crushing them at every speed bump, like where the stock muffler goes.
Old Apr 17, 2003 | 12:00 PM
Thebeast431's Avatar
Why would you want 2 mufflers? That is twice the restriction. Dual exaust is one pipe going from either side of the engine, never meeting oneanother, and hitting individual mufflers. I think you would be happier with true dual straight pipes, w/o a muffler. But then you will have a problem with lack of back pressure.
I think you should buy a stock exhaust from someone off this board, probably $50 max for it all probably free if you ask nicely, and put that back on and get a cut out for $30. For $80 you can have more power than a catback exhaust, but the quietness of stock exhaust for highway use.
I think you were referreing to the GMMG chambered exhaust. I love the sound of mine but I have no personal experience with the Summit chambers. I am glad you know about the Flowlessmaster.
Old Apr 17, 2003 | 01:31 PM
fbird95's Avatar
Dual exhaust after the car. Thats the kind of silly-ness i found on my freinds thunderbird sc.
Old Apr 17, 2003 | 02:37 PM
RedWolf's Avatar
[QUOTE]Originally posted by Thebeast431
[B]Why would you want 2 mufflers? That is twice the restriction.
isnt the CMMG a 2 muffler set up? i thought it was, tis why i got the 2 mufflers to simulate the CMMG.
thanks all for your opinions
Old Apr 17, 2003 | 02:49 PM
I guess I wrote wrong, my bad.
GMMG has basically 2 resonators, not mufflers. With that said they flow straight through instead of being moved around, ie. Flowmaster which reflects the exhaust in a number of directions.
In a way I guess you can call GMMG 2 different mufflers, but they are really just resonators.
Travis
Old Apr 17, 2003 | 02:50 PM
Black_Z28's Avatar
Just so you know, it's GMMG. I say use the the pipe from the cat, and use a Y-pipe to use both mufflers. One muffler for each side.
Old Apr 17, 2003 | 02:53 PM
RedWolf's Avatar
oops..thanks....i knew it didnt look right when i was typing it
Old Apr 17, 2003 | 02:58 PM
RedWolf's Avatar
heres the mufflers ad and desription web site.
http://store.summitracing.com/partde...t=SUM%2D630730
Old Apr 17, 2003 | 03:21 PM
mr diabolical's Avatar
those caught my eye while looking through a new summit magazine i received two days ago. i was thinking of buying one to replace the i-pipe and just ditching the rear muffler all together
Old Apr 17, 2003 | 03:52 PM
ShelbyZ28's Avatar
Those look almost exactly like the chambered sections on the GMMG exhaust. It will be interesting to see what it sounds like. The only place I can think that you could put one is right before the axle. I don't know if you could sqeeze two in there. It would kinda be like a loudmouth with a chambered section. Or you could do it like GMMG does but that would cost a bit more http://www.gmmginc.net/html/chamberedexhaust.html . It would be pretty loud with just one but cheaper. Good luck and let us know how it sounds.
Bryan
F'n1996Z28SS
Aug 23, 2023 11:19 PM
MadMav
Feb 6, 2015 11:02 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
