AC will not blow???
Old Apr 18, 2003 | 07:06 AM
Bad T.A.R.A's Avatar
AC will not blow???
Hey I recently changed my sparkplug wires and I dont remember if they still worked right after this but now my ac is not blowing through the vents. It will come out the bottom and out of the really small ones up top by the windows but not out of the regular vents.
Old Apr 18, 2003 | 07:51 AM
If it mainly blows out the defrost and floor, you probably disturbed the vacuum line that feeds the mode switch on the dash. It is fed from the intake manifold and goes to the check valve by the a/c evaporator. The check valve is easy to crack, but it is a cheap part to replace. Try looking those places first.
drt
Sep 27, 2015 04:39 PM
z28newbie
Sep 9, 2015 10:26 AM
z28newbie
350350
14
Aug 11, 2015 12:03 PM
96SilverRam
Aug 9, 2015 04:15 PM
