Is there a company that makes a bronze gear for the oil pump drive, that actually fit
Old Apr 16, 2003 | 10:10 PM
BrianZ28's Avatar
I bought a comp cam, and did not know at the time that the cam gear needed to be treated. So I ordered a bronze oil pump drive gear, but the inner diameter is not the same as the stock gear that you remove. Is there a company that makes a bronze gear fitted for the Lt1's, thanks?
Old Apr 16, 2003 | 10:56 PM
Black95Form's Avatar
Brian,
I ran into this with cam I bought recently. I ordered a billet cam. It turned out comp used a different billet for the LT1 so it did not require the bronze gear drive. Do a search in the advance section. Lots of info on what you will need if your cam actually requires a bronze drive.
Michael
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Queens94z28
Dec 20, 2014 09:11 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Jul 4, 2005 05:00 PM
