quick question
Old Apr 16, 2003 | 08:18 PM
z28nate's Avatar
quick question
I working on getting the whole cat back done. What would be the best muffler to have(I like em loud)?
And also I think my pcm may have been programmed before I bought it because it shifts at 6200 rpm and it seems to run better than some of the other ones I test drove is there any way to find out?
Old Apr 16, 2003 | 08:22 PM
ford's Avatar
If you like loud. go borla adjustable or SLP loudmouth. Its a full cat back exhaust and they flow awesome as well.
Edit: your tachometer is most likely just off by a little(most are). I think they shift at 5800 stock. then again they could have raised the shift point.
The only way you will truly know is if you hook it up on a computer and see where its set.
alex5366
Feb 17, 2015 09:07 AM
94Form
Feb 10, 2015 11:23 PM
Jan 23, 2015 01:13 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
