How to bold Motor Mount
Hope you did'nt do both at that same time. If you did, try to get one side to line up as best as possible and stick on bolt in one hole. Then you just have to keep playing with the other side to get them to line up. If you can seperate the mounts from the motor, do it now. Bolt on the mounts, and then the motor. One bolt on each side is allot easier to line up then three or four.
