Jet-hot/Hooker LT guys inside please
Old Apr 17, 2003 | 11:50 AM
showtime89's Avatar
The #1 primary on the drivers side, when do you put that pipe in? once you have the rest of the header bolted up or before? Should I have left the steering knuckle apart while I do this?
Old Apr 17, 2003 | 04:42 PM
showtime89's Avatar
Graci on the sanding bit. Made it a heck of a lot easier.
Old Apr 17, 2003 | 05:04 PM
96z's Avatar
96z
I would do it after you have the rest of the header bolted up. Itll make it a little easier to line up...
Old Apr 17, 2003 | 09:51 PM
showtime89's Avatar
I tried that but when I would rotate it into place it was messing up the gaskets.
Old Apr 17, 2003 | 10:36 PM
Robbie's Avatar
I bolted the header on first then put the slip tube on.
Magenta_Hearts
Mar 25, 2015 10:24 AM
cmsmith
Mar 14, 2015 03:48 PM
carl.froehlich
Mar 13, 2015 12:38 AM
squarehead
Nov 21, 2014 08:02 PM
Red97LT1
Aug 7, 2002 05:45 PM
