How wet can the opti get?
Old Apr 17, 2003 | 10:31 AM
96z's Avatar
96z
I have heard from some people that a vented opti can get wet, dry out, and still be ok, and the unvented cant...Is this true? Mine didnt get wet but I was wondering how some people can powerwash their engine, while others do a cam install, get a little water on it from the WP, and the opti is toast.
What technically is the differnce between the vented and unvented versions? What was the reason for the change?
Old Apr 17, 2003 | 11:04 AM
Brettinator's Avatar
I think you and I have vented since were 96-97 but I am curious to this myself. I received a SES light from going through an automatic car wash and it didn't even do the undercarriage wash option, it started blinking then went solid. I had it cleared the next day and it's fine, runs fine but I was told they are very sensitive still even with the vent. As for ruining it I wish I knew because they are about 400-500 bucks from GM...that's with the cap/rotor which is the only way they will sell it....as a set...
Old Apr 17, 2003 | 01:40 PM
96z's Avatar
96z
Yeah....I know I have the vented I was just wondering if anyone knew any specifics on the topic...
Old Apr 17, 2003 | 02:09 PM
Bralgar's Avatar
Just from my personal experience, my waterpump one day decided it would pee (well actually a full fledged ****) out the weep hole all over my opti. I never noticed a drivabilty problem except for my low coolant light came on and I was losing my power steering (wet belt was slipping) I changed the water pump and I still have no problems with my opti acting screwy, and it got soaked when I first discovered the leak. And as you can see from my sig, I have a non vented opti.
Old Apr 17, 2003 | 02:29 PM
ixd97z28's Avatar
My waterpump decided to take a leak last week. It did get the opti wet and while I was changing out the waterpump I got my opti pretty wet. No problems here. I have the vented opti as well.
Dan
Formula Steve
Sep 19, 2023 08:31 AM
94Maroz28
Oct 27, 2015 04:38 PM
Ks0209
Oct 1, 2015 07:32 AM
colts0455
Sep 27, 2015 01:07 PM
jayblev95
Sep 26, 2015 09:44 PM
