pcm prog-VATS??
Old Apr 17, 2003 | 11:17 AM
1QUIKTA's Avatar
pcm prog-VATS??
What signs are present when the VATS is enacted? Besides the obvious that the car won't run. Make a long story short-I am trying to use a PCM from my buddys 94 Formula (I have a 94 Trans Am GT). The aftermarket tune is loading fine, it just has a SES light that flashes rapidly and the car starts then dies. The programming is fine and we are loading just as we did last year, which turned out fine. Car volts are at 14 and we tried the DOS and winflash versions both. We have not tried again with my original PCM, the other one was socketed first. Is there a VATS module that has to match VIN numbers maybe? Just a shot in the dark, but worth asking.
Thanks,
Chris
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
MDZ28
11
Sep 24, 2015 09:15 AM
