Accel Ignition Questions
Old Apr 17, 2003 | 03:21 PM
Fastbird93's Avatar
I see that the Accel 300+ setup had two different types listed:
one for 93-95 with a coil and one for 96-97 without a coil.
I'm converting to a vented opti in my 93, and need to know if that affects which system I need to order. What are the differences, and which do I need?
Old Apr 17, 2003 | 04:54 PM
JSK333's Avatar
The differences are in the harnesses used that go between the coil and the box.
If you're keeping the stock-type coil and wiring, then you should stick with the '93-'95 version.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
lbrowne
Nov 13, 2011 04:25 PM
john97z28
Aug 26, 2002 04:23 PM
ferraricameron
Jul 29, 2002 07:46 PM
