obd 2 codes
Old Apr 16, 2003 | 06:30 PM
z28nate's Avatar
obd 2 codes
I just had my 96 lt1 scanned and came up with (intermediate misfire) any one know where to start? The reason I took it in was I could hear what I thought was a spark plug sparking and the engine would miss. I thought it might just be a wire but all the wires seem to be good.
Old Apr 16, 2003 | 07:13 PM
What was the specific code number? Probably a "random" misfire. If you hear a snapping noise coming from the engine, you probably have a wire that is arcing. Take a look at it in the dark to confirm this.
Old Apr 16, 2003 | 07:51 PM
z28nate's Avatar
P0300 Random/Multiple Cylinder Misfire Detected
P0300 Random/Multiple Cylinder Misfire Detected was the code. I tried the dark apporach and could not see anything. One guy told me it could be the injectors or distributor. What do you think?
Old Apr 16, 2003 | 07:57 PM
If you hear the snapping noise and feel a miss, you can bet there is an arc somewhere that you have not seen.
Old Apr 16, 2003 | 08:01 PM
z28nate's Avatar
That is what I thought too, It seems to always come from the same side (passenger of course) but if it is a wire would it not give me a specific cyclinder misfire code?
Old Apr 16, 2003 | 08:08 PM
The diagnostics are not fool proof. If the crank position sensor does not detect enough change in speed to be able to figure it out, it won't throw a code. If your plug wires are old, they should be changed anyway.
cmdeshon
Jan 4, 2015 11:15 AM
Timberwolf
Aug 18, 2002 07:39 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
LT1
Jul 2, 2002 08:27 PM
