TB bypass=broke engine?
Old Apr 16, 2003 | 11:14 AM
All4Chevy's Avatar
Hey guys, yesterday I did the throttle body bypass on my car and everything seemed fine...i forgot to plug my intake sensor back in until this morning, but that didnt seem too bad. After I got out of school and got back in my 96 Z, the service engine light came on about 1/16 of a mile down the road....are these related, is there a sensor in the TB that knows the coolant isnt going in there...has anybody else had this problem? Im going to buy a scanner for my car later, but for now i dont have one.
Old Apr 16, 2003 | 11:22 AM
PatriotTA's Avatar
As far as I know, there is no sensor in the TB to detect coolant flow or anything. I never had any codes in my '95 when I did the TB bypass. It might have been due to you having the IAT unplugged (even if you plugged it back in), but I don't know. If you are going to buy a scanner just for this, you can get it scanned for free at AutoZone or Murray's. HTH
Old Apr 16, 2003 | 11:32 AM
97FormulaWS-6's Avatar
The TB bypass should have NOTHING to do with the SES light, the PCM has no idea that there is no coolent flowing through the TB.
And if you don't want to buy a scanner, and just want to know what code it is AutoZone does free scans...
Old Apr 16, 2003 | 11:42 AM
brokenz's Avatar
Try resetting the PCM. I'm sure it's probably just from having that sensor unplugged. Unhook the battery for 15 min. and then no more light.
Old Apr 16, 2003 | 11:48 AM
Brettinator's Avatar
if unplugging the PCM for 15 mins (does not always work depending on the code thrown) then go to Autozone they will check your PCM code for free and clear it. The TB will not cause this light, you leaving the intake sensor unplugged caused this light. Good luck.
Parts Wanted
Mar 17, 2015 11:24 PM
CARiD
Jan 27, 2015 06:27 AM
sscott
Jan 17, 2015 04:30 PM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
Speeds8erM-1
Jul 18, 2002 11:36 PM
