P0336 Random Mult. Missfires
what are the possibilites of why i got this code?
codes 301-309 are specific cylinder missfires......why didnt i get one of those so i know which cylinder is misfiring?
any help is appreciated.
There are lots of possibilities. We need to know a bit about your car too though. What mods do you have or is it basically stock?
Age of plugs and wires? Coil? Optispark?
Any aftermarket tuning? (after my cam install I got P0336, and it was because I was running so rich at idle it was washing out the spark...leaned it up and it went away).
my bad.
1996 formula
hooker long tube headers
spark plugs (NGK Iridium) are like 1-1.5 months old
Taylor 8mm wires same..about 1-1.5 old
TBB
LT4 KM
descreened/ported maf
thats all i got in the car...other than that..its stock.
1996 formula
TBB
LT4 KM
First thing I'd do is check to make sure you haven't burned plug wires and/or the wires are securely snapped onto the plugs and the opti.
Then I would say double check the coil and module and make sure they are working properly...does the car drive fine or is it giving you problems?
Could very well be the opti. Mine is beginning to slowly go and I'm getting P0300 which is random missfire. I get it once every week or so over the last 6 mos. and I've had the cam in the car for over 2 yrs and never had the problem before.
well my car is running ok..
if i floor it when im ideling...it kinda hesitates till i get up to like 2500 rpms then it shots up badass...but from idle or 1000-2500 or so..it kinda laggs.
i get code 300-missfiring
and code 336- crank position sensor...
those 2 codes go hand in hand? cus i been reading posts and i notice those 2 are always together.
well not yet.....give me some time
so do i just check the plugs and wires? do i get a new sensor?
also..it was throwing code 107..map? i know what it is and what it looks like...but whats it for? if it throws that code..does that mean the map is gone? and i need a new one?
believe me...i will! lol
so check wires and plugs....wires on the spark plug and wires on the opti right? make sure they are all connected correctly.
if a wire is wronG on the spark plug or opti.....what it throw a diff code? so i can rule that out if so.
edit: forgot the G
edit: forgot the G
All I'm saying is if there is a wire or wires that aren't on the plugs all the way or on the opti all the way it could cause misfires at low RPMs if the spark is not strong enough to jump the gap beween the plug wire terminal and the tip of the plug. Make sure they are all snapped down good and that none of them have burned on your headers.
ok i understand that part.
but my question is.
if i connected a wire to the wrong location on the opti...would it throw a different code?
lets say i put wire #3 on #6 and vise versa? that i got 2 wires mixed up...is that a possibilty? or would it throw a different code..or the car sound ugly...or not start...?
but my question is.
Possibly, because it would definitely be missfiring, but if that were the case the problem would not clear up at higher rpms, it would run like crap all the time. It is worth checking though, just make sure you have all the wires in the right order on the opti.
tdigger9899
Sep 7, 2015 10:56 AM
