Part number for the good oil pump spring?
Old Nov 30, 2004 | 08:39 PM
BlackLT1_TX's Avatar
I think it is the white spring that everyone uses around here. I am running a brand new Melling replacement pump and someone mentioned that since I had them tack weld the pickup on the pump I should replace the spring just incase the heat messed it up.
So does anyone have the part number for a good spring to use from the general?
BTW- you just slide out the pin and put the new spring in, right? Do you have to use anything on the pin to keep it in place?
Old Nov 30, 2004 | 10:47 PM
brandboZ28's Avatar
Re: Part number for the good oil pump spring?
GM white oil pump spring Part Number: #3848911
Info taken from a thread found from a search.
And yes, just tap that pin out and the spring should come right out. Be careful, it could go flying so you might want to place the oil pump next to a block or something to keep the spring from getting lost.
parkers Z28
Mar 11, 2016 08:14 PM
oldschool
Feb 9, 2016 09:21 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
CobraEatr
Jul 22, 2002 09:49 AM
