Help! No crank, disabled VATS
Old Dec 1, 2004 | 05:07 PM
kevm14's Avatar
My VATS started acting up leaving work today. Took 3 "SECURITY" light resets and it finally cranked. When I got home, I got out the laptop, fired up Tunercat, unchecked "VATS enable" and "VATS diagnostic" in the switches list. Flashed PCM successfully. But the damn thing still won't crank and the "SECURITY" light still comes on! WTF!?
Is it something with my Tunercat definition file or something? I'm using the $EE mask version 'BG,' Tunercat version 2.00 and the form library version 9.4.
Old Dec 1, 2004 | 05:10 PM
Z95m6's Avatar
Re: Help! No crank, disabled VATS
The Vats is turned off in my PCM and everyonce in a while i still get a security light. This is a complete theory but i think the key still has to make a connection, just the resistor value doesn't matter.
Old Dec 1, 2004 | 05:20 PM
kevm14's Avatar
Does your starter not crank when the light comes on? What should I do?
Old Dec 1, 2004 | 05:28 PM
Z95m6's Avatar
Its only happened to me twice in the last year or so. It seemed to happen when i just slammed the key in and tried to fire it. I would just pull the key out, wipe it off, and wait until the security light went off then try again.
kevm14's Avatar
New update: Went outside to try cranking again. Turned key to start, nothing happened. I kept holding it and it cranked for like half a second and fired, and I want to say it stopped cranking BEFORE I let off the key (or maybe it was me). But the point is, I was holding it in start before it cranked. The interesting thing is, a friend of mine has a 94 T/A and he described this exact thing as what his car does sometimes. WTF is wrong with my car?
Old Dec 1, 2004 | 05:35 PM
kevm14's Avatar
Update 2: My car is idling outside and I went to go sit in it and just ponder WTF is wrong with it when the "security" light came on. Can somebody with an FSM tell me what this means? Seems to me this shouldn't happen. I didn't even touch anything. Oh yeah, and my friend's 94 T/A does the same thing sometimes (security comes on while driving). I'm assuming it means something, but what?
Old Dec 1, 2004 | 05:53 PM
mitchntx's Avatar
If you lightly push in or pull out the key, while turning the motor over, will it crank?
While the motor is running and the light is on, if you push in or pull out slightly on the key, does the light go off?
A late model TA started acting funny and randomly not wanting to start. The ignition switch was bad ...
Old Dec 1, 2004 | 05:56 PM
kevm14's Avatar
Final update(?): My car is doing a pretty good impersonation of an old british roadster, with wiring by Lucus. I just drove to Autozone for plug wires (see my other thread ) which they did not have. It restarted for me in the parking lot. Drove back to my apartment. Shut it down and restarted about 6 or 7 times in 2 minutes. Worked each and every time. I swear, these cars can be THE most finicky POS's sometimes...
Anybody want to theorize some more?
Old Dec 1, 2004 | 05:57 PM
kevm14's Avatar
I have tried that and it makes no difference. If my "security" light wasn't involved in this, I'd tend to blame the switch, but I think mine is fine.
Old Dec 1, 2004 | 05:59 PM
Z95m6's Avatar
I was thinking ignition switch until he said the security light came on. Mine has never come on while driving.
Old Dec 15, 2004 | 09:53 AM
kevm14's Avatar
http://impalassforum.com/noncgi/ulti...;f=33;t=007103
I think this answers my question and hopefully will help someone. Last question: does anybody know for sure where the VATS module is located in my 95 Z28? I'll check shoebox's site and my Haynes manual...
walt355
Mar 16, 2016 09:35 AM
95_lt1_z28
Aug 30, 2015 06:17 PM
Aug 7, 2015 08:52 AM
Catmaigne
Jul 14, 2015 05:17 PM
