cam help
Old Dec 1, 2004 | 12:56 PM
camaroKid223's Avatar
cam help
hey guys i know its talked about alot but i was hopeing you could give me alittle more info that would help with what i have done to my car. i have everything in the sig and plan to keep the stock heads. i want 1.6 roller rockers and new valve springs along with the other basic stuff. what cam would you recomend that makes good power and has a nice lope? in an early post i asked about maybe a cc306 but some people thought that was to big for stock heads, but then i did a search and read about people with stock heads saying they liked it. any help would be great!
Old Dec 1, 2004 | 01:02 PM
fesgali's Avatar
Re: cam help
The compcam XE series seem to work pretty good with stock heads. I've read people getting an average of 350hp out of the cam. I think the XE cams are pretty much pushen the stock heads as much as you'd want to push them and still get a nice lobe and performance out of it.
Compcam has also come out with the XFI series (like 2 weeks now) but i still can't find the cam info, worth looken into.
Old Dec 1, 2004 | 01:23 PM
Re: cam help
you dont happen to know the lsa for that do you? i have a 114lsa at the house now but i dont think its the cam im going to want. i really dont want to do all the work of the cam install only to find out i want a bigger cam and have to do it all over.
Old Dec 1, 2004 | 01:30 PM
fesgali's Avatar
Re: cam help
Check on Thunder Racing to be sure, but i think the biggest XE cam has a 112 LSA. There is about 5 different XE cams to choose from.
Old Dec 1, 2004 | 03:35 PM
Re: cam help
how would a cam with a Duration@ .050 230/236 LSA 112 544/.554 with 1.6 rockers compair to the cc306?
Old Dec 1, 2004 | 03:54 PM
Re: cam help
also if it helps i would like car to make good overall power but dont want to lose to much low end. i have a stall seems to flash around 3200 now and am willing to go to 3.73 or 4.10 gears which ever will help the most
Old Dec 2, 2004 | 02:45 PM
Re: cam help
also do people take a big hit in low end power with the cc306?
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
