Z06 MAF on a LT1 ?s
Old Dec 2, 2004 | 09:38 AM
joshp007's Avatar
Exclamation Z06 MAF on a LT1 ?s
I have a Z06 Maf that I am going to put on my LT1. Does anyone know who makes the adapter for the plug? Pm me if so. Thanks for all the help
Old Dec 2, 2004 | 09:48 AM
944v8inDFW's Avatar
Re: Z06 MAF on a LT1 ?s
unless you get a PCM tune the ZO6 MAF is a BAAAAADDDD idea. Sort of a bad idea even with a tune unless you have big mods on the engine and from what i know the sizes of the in and outlets are 4 inch instead of 3 1/2.
No to burst your bubble but you may cause more issues than not. If you do a search this topic was talked about recently by one of the PCM tuners on this board.
Moral of the story: Yes it can be done but you need to throw some money at it in the form of a tune and new plumbing adapters.
Old Dec 2, 2004 | 12:44 PM
zhevy-1's Avatar
There's some useable information here, that can also answer your original question...
http://web.camaross.com/forums/showt...hreadid=258624
Old Dec 2, 2004 | 01:11 PM
Red96Lt1's Avatar
I would say a bad idea. There are people making gobbs of HP on the stock MAF.
Old Dec 3, 2004 | 06:41 PM
96capricemgr's Avatar
Your stock MAF can comunicate with the pcm to a higher airflow. The ZO6 sensor can read a lot of flow but the stock pcm can not understand it past about 350rwhp I believe and your stocker is good far beyond that. I am among the wasted money on this sensor and regretted it crowd, I had proffessional tuning help and several fellow enthusiasts sending me MAF tables and I never could get it to run right, always wanted to be rich BLMs around 113-115, milage was down and topend was compromised, and that is compared to my tiny 3" b-body MAF and I do have some mods including a ZZ3 cam.
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
hotrodyou1
Dec 20, 2014 10:05 PM
pete53
Dec 9, 2014 07:31 AM
ChrisFrez
Dec 7, 2014 06:01 PM
formula218
Dec 2, 2014 04:27 PM
