just came from autozone got code p0101??
Old Dec 1, 2004 | 02:46 PM
red96z's Avatar
whats the deal with the code couldnt figure it out?
Old Dec 1, 2004 | 02:57 PM
skibbe_96z's Avatar
Re: just came from autozone got code p0101??
I believe it is a Mass Air flow Circuit Range/Performance Problem. Not for sure at the moment though.
Old Dec 1, 2004 | 06:26 PM
captain_foustas's Avatar
yup, clean your maf, check your tps and clean your filter. thats where i would start.
when did the problem code start?
Old Dec 2, 2004 | 09:11 AM
red96z's Avatar
what would cause this sort of a code?what gives
Old Dec 2, 2004 | 09:58 AM
skibbe_96z's Avatar
If your screen is in, there could be debri or leaves or something blocking the screen so not enough air is going through the MAF. Your filter could be dirty so not enough air. Just try to clean out your whole intake system and see if that fixes the problem.
Old Dec 2, 2004 | 02:32 PM
The PCM checks the air mass flow reading from the Mass Air Flow (MAF) sensor against the same value calculated from the speed-density readings (IAT, MAP, RPM, VE). If there is a serious mismatch between the two readings (>40% at low flow, >25% at hight flow) the PCM sets the code. This code will not set if there is a DTC for MAP or TPS, so that sort of rules those out as secondary causes.
Most likely, the flow numbers from the MAF sensor are incorrect... dirt on the sensor wires would explain it. Blocked air flow would not be a likely cause, unless it causes a major maldistribution of air flow velocity across the face of the meter, resulting in incorrect flow readings.
uraceulose
Oct 14, 2002 08:50 AM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
camaro_ss01
Jun 25, 2002 09:38 PM
Z28AZ
Jun 14, 2002 04:16 PM
