whats the exact difference in the impala head gasket and the camaro?
i was wondering the difference in thickness of the two for a 96 if that matters.i thought the impala was .039 in thick but im not sure for the camaro am i correct?
Re: whats the exact difference in the impala head gasket and the camaro?
The stock LT1 f-body gasket is .049 and the Impala head gasket is .029. By going with the Impala head gasket you are going to raise your compression ratio slightly.
Jeff
Jeff
