How much spray on a stock rotating LT1 w/CC306
You can see my mod's in my sig. How much spray do you think that a motor like this can hold, I have ARP bolts throughout, but still on a stock bottom end (although the rodcaps are resized, the crank is polished, the rings and hone are new, and all the bearings are new).
I really dont want to spray the **** out of it, but a 75-100 shot sounds nice to get a deep 11.
-james
-james
A 100-150 shot should be fine as long as you have adequate fuel.
I'm spraying a NX 175 shot with heads and cam on a 77k mile stock bottom end.
Re: How much spray on a stock rotating LT1 w/CC306
If I am spraying wet, I would just need a bigger fuel pump right, as the injectors wouldnt have to fuel anymore to compensate, correct.
And if that is correct, why couldnt I just put a T-Rex inline, and leave the assembly in the tank stock?
Thanks,
James
Thanks,
James
So there isnt a problem sucking all that extra fuel through the current fuel pump?
I mean, the stock pump would be sucking up fuel, but that T-Rex would be sucking harder, it wouldnt screw up the in tank pump would it?
On my charged stang I ran a 255 in tank and a T-Rex with a Vortech and it always held good fuel pressure, and they are so easy to install (unlike our intank pumps
Lemme know!
)Lemme know!
Lemme know!
)Lemme know!
Ya, I definitly have learned you dont want to cut corners on the fuel side, especially with power adders. Rich=Slow, Lean=Fast until it blows up, and somewhere in the middle lies perfect.
Would I need to modify my tune at all to compensate for the nitrous. I know the PCM wouldnt even know it was there since it would be sprayed after the MAF and the extra fuel would come from the wet kit, but I dont know if there are timing issues and what not.
Thanks,
James
Thanks,
James
Thanks,
James
Thanks,
James
Originally Posted by ChrisUlrich
How many sprays and how often are we talking here to "Dial it in"
oldschool
Feb 9, 2016 09:21 PM
jb4xx
Feb 2, 2015 10:00 PM
