air! removal on 96
Re: air! removal on 96
94-95's are 22mm i believe 96-97's are diff as my buddy tried 22mm on his 97 and they wouldn't work. If i was you i would just take the air tubes and cut them. Then take off and weld up the hole in the fitting that screws into the manifold.
I agree with Z95M6 you will need a dremel with some cutting wheels . I used the exstention wand to help get in the tight spaces . Takes a lot of patience to get that dang thing out as it is wrapped tightly around the front of the motor. Just curious why are you removing the AIR system ? Doesn't give you any HP.
You need to remove the stock fittings and then go to Home depot and pick up some caps from the plumbing section. Bring the stock ones to get the size right. Then you can paint them with some high temp paint to make them look better on there. I think this willl be a lot cleaner and more professional look. This is what I did and it worked great.
thanks for all the help guys
Victor Lamb
Aug 26, 2017 02:52 PM
95chwagon
Jan 13, 2015 09:19 PM
