Bigger injectors necessary?
Old Dec 5, 2004 | 03:34 AM
'93 Z28's Avatar
Talking Bigger injectors necessary?
A quick question:
Will I need bigger injectors for this application?
I am installing the Hotcam into my car and was wondering if I should add them to the list.
This is what I have:
1993 Z28 M6
SLP 1 3\4" Mids + y-pipe
3" "hi flow" cat
Loudmouth exhaust
K&N FIPK
Hypercrap chip
hurst billet\plus shifter
4.10:1's
tb by-pass
Suspension: (if it helps any)
STB
Lca's w\ relocation brackets
Eibach pro w\ revalved bilsteins
double adj panhard rod
spohn torque arm
poly bushings on sway bars
17x9.5 z06's
That's all that I can think of
What do you think motor wise that I will need to complete installation of the hotcam kit?
Also -- if anyone knows of a better spring that will fit the stock heads and provide a safer clearance than the ones provided in the kit that would be immensely appreciated!
Old Dec 5, 2004 | 06:34 AM
Loadre's Avatar
Re: Bigger injectors necessary?
You shouldn't need them for that application. Add much more power and you'll need to upgrade sometime though.
http://www.cmotorsports.com offers a better spring that fits the stock heads I believe.
Old Dec 5, 2004 | 04:22 PM
whatsup's Avatar
When I did my cam upgrade on my 93 I went up to the 24# ones that the 94-97's have. Do you need to? probably not.....but you can pick up some 24#ers pretty cheap on this site or ebay and since you are going to probably get a tune it's a good time to do it. If you get a tune Alvin at pcmforless is great with 93's. Also check out this website for us speed density guys...http://www.speeddensity.org/
93 RedBird
Nov 15, 2015 08:24 AM
form94
Sep 23, 2015 07:30 AM
plattted
Parts Wanted
Sep 13, 2015 07:17 AM
95craz28
11
Sep 12, 2015 07:47 AM
RubyRedIrocZ
3rd Gen / L98 Engine Tech
Sep 10, 2015 01:48 PM
