What should CKP read with meter?
Old Dec 6, 2004 | 07:24 PM
RansZ28's Avatar
Question What should CKP read with meter?
I am having problems with mine. When I read it with a meter, what am I looking for?
Old Dec 9, 2004 | 06:40 AM
slopokrodrigez's Avatar
Re: What should CKP read with meter?
You can't read it with a meter to check the performance. It is a magnetic sensor. The only way to monitor it's performance would be with an O scope, or of course a scanner. But even if you monitor it with a scanner and see it's not reading correctly, it's still probably a wiring problem.
Since you already replaced it, forget about the sensor. The problem should be in the wiring or the PCM.
I responded to your previous post by instructing you to check for ground, 12 volts and ohm the signal wire to the PCM. Have you checked these 3 items?
Dave
Old Dec 9, 2004 | 10:14 AM
RansZ28's Avatar
I am going to a friends that has the meter reader. I will let you know what we find. You have been very helpful - THANK YOU!
TitoPR221
May 26, 2015 12:20 AM
Magenta_Hearts
Mar 30, 2015 09:42 PM
Moshbmx1
Feb 17, 2015 10:51 AM
z28projects4ever
9
Jul 16, 2002 07:48 PM
