Hot Cam Questions
Old Dec 2, 2004 | 09:59 PM
Eff's Avatar
Eff
Hot Cam Questions
Ok, I got a Lt4 Hotcam, with the springs and retainers. I want to throw it in my basicly stock 94.
The question is I'm trying to do this as cheap as possible. but I'd rather spend an extra $150 then do something that will cause problems down the road.
Is it ok to go with the comp cams pro magnum 1.6 rockers?
Old Dec 2, 2004 | 10:04 PM
Z95m6's Avatar
Re: Hot Cam Questions
Promagnum rockers are a very good rocker arm. Thats what i'm running, and am very happy with them. If your car doesn't have headers on it, i would at least do those first.
Old Dec 2, 2004 | 10:06 PM
ejfagala's Avatar
As long as they are self allinging rockers or you will need guide plates and hardened push rods. The Pro Mags are nice (I have used both crane and Comp) but they are a bit more work with the valve covers because of the bigger trunions.
Old Dec 2, 2004 | 10:45 PM
Eff's Avatar
Eff
What exactly do you mean by work....
will they fit with stock valve covers?
Old Dec 2, 2004 | 11:13 PM
Z95m6's Avatar
Yes they fit, the valve covers just take alittle modification which i believe has to be done with any roller rocker.
Old Dec 3, 2004 | 08:50 AM
izzyz28's Avatar
I didn't have to touch my valve covers and I'm running the GM 1.6 roller rockers that cam with the HOTCAM kit. There's nothing wrong with running the rockers in the kit, but if you don't have the whole kit then you might as well get NSA RR's and guide plates.
Old Dec 3, 2004 | 08:09 PM
Kory 88 Iroc Lt-1's Avatar
I've got promags on my engine with the hotcam. I got them because I wanted to use 7/16" studs instead of the 3/8' ones that are required with the rockers that come with the hotcam kit.
I like them, I had to use guideplates and trickflow pushrods though.
Kory
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
LT14LIFE
Feb 9, 2015 09:35 PM
Queens94z28
Dec 20, 2014 09:11 PM
GigaMp3z
Feb 20, 2003 02:57 PM
Burn_Out
Aug 18, 2002 08:49 AM
