Stumbling After Plugs
Old Dec 6, 2004 | 07:54 AM
Marc95z28ConvM6's Avatar
Question Stumbling After Plugs
95 Z28 Conv M6
Ran rich but smooth. Failed emissions.
Plugs had 160,000 (I was dreading the task).
Air Filter bad - See no light...
Replaced Plugs - Bosch Plats
(About 4 hours; Superman technique from top; removed Alt to get to #2 and worked #8 from bottom. Used Spark Plug socket with 3/4 socket over it.)
Replaced A/F - K&N
Wires on tight.
Opti about 60K. (Remember ran fine before)
Now it stumbles when accelerating.
Should I be looking at the MAF?
Can it be cleaned and how?
It's great to be back here!!!
Old Dec 6, 2004 | 09:37 AM
Re: Stumbling After Plugs
What is the thing before the throttle body? MAF or MAP?
Old Dec 6, 2004 | 11:12 AM
95LT1Z28's Avatar
It is your Bosch platinum plugs causing the problem. I know you don't want to change them out again, but put in the stock AC Delco's or NGK TR-55 non platinum plug. Your problem will be gone after that. Same thing happened to a buddy of mine who installed the Bosch platinum plugs on his firehawk.
Jeff
Old Dec 6, 2004 | 12:14 PM
If the MAF Cleanoing doesn't work, looks like plugs again.
Lesson Learned. New type Air Filter (K&N) brings additional variable into the mix.
Old Jan 10, 2005 | 09:06 AM
UPDATE:
Cleaned MAF, same symptom (ran better, no more popping).
Disconnected MAF same symptom.
Replaced Bosch with AC/Delco. PTL - Symptom Gone!!!
Sure enough a couple of Bosch Plugs had loose tips....
Old Jan 10, 2005 | 08:14 PM
SSmoked's Avatar
I have bosch plat's on my car now and it runs fine. Ill be switching thoes out next time i take a trip to summit. Thanks for the heads up.
KYWes
Jun 14, 2022 06:52 AM
gonzo275rltw
Jul 11, 2015 04:19 AM
pete53
Jun 27, 2015 09:08 AM
Nellsw88
May 27, 2015 10:27 PM
