switched to 0w30 castrol
Old Dec 2, 2004 | 09:49 PM
chy20k1's Avatar
so i got some of that 0w30 synthetic castrol and a k&n oil filter, figured id give it a shot after reading that long thread on it. other than the increased protection im assuming im getting now it also had a nice side effect, seems i get an average of 1 - 2 psi more oil pressure while driving around and now my oil starvation problem is non existant anymore. used to go down to ~40psi at wot, usually around 3500 rpms, now its 60+ all the time at wot im happy.
Old Dec 2, 2004 | 10:06 PM
Bryan Smith's Avatar
Re: switched to 0w30 castrol
I put some in, in this last oil change. I dont think ill be going back to mobile 1 again. like you said i too notice the needle a tad higher at WOT and idle now.
Old Dec 2, 2004 | 10:25 PM
93LT1355's Avatar
I have been reading the oil threads lately and have been wondering if I need to change. I have been running M1 5W-30. Would it be better to change to the Castrol Syntec 0W-30, and would I be able to run this oil in the winter?
Old Dec 2, 2004 | 10:43 PM
budvol's Avatar
M1 0w-40 much easier to find
Old Dec 2, 2004 | 11:16 PM
lt4 fd's Avatar
mobil 1 5w30 is way too thin for an lt1 from everything ive ever read, im sure patman will agree. Its a great winter oil and its what patman used during the winter in canada from what I remember reading, probably a fine summer oil as well. Ive heard M1 0w40 is recomended as a similarly good oil to experiment with.
Old Dec 3, 2004 | 06:02 AM
TQdrivenws6's Avatar
Can someone post the barcode number from the back of the bottle of the German Castrol 0w-30?
Thanks,
Chris
Old Dec 3, 2004 | 08:37 AM
kmook's Avatar
Advanced Tech Moderator
Thanks,
Chris
If nobody does by this evening i'll get it for you when i get home.
Old Dec 3, 2004 | 09:32 AM
I have been asking in numerous threads for a couple days now and noone has been able to get me a number.
Old Dec 3, 2004 | 03:24 PM
chy20k1's Avatar
Thanks,
Chris
79191 00068
Old Dec 3, 2004 | 03:37 PM
79191 00068
EDIT: The guy at autozone said he needed the two little numbers on there also, there should be one preceeding those numbers, and one following them.
Ericksd
Jan 20, 2016 06:07 PM
IndyZman
Oct 22, 2015 02:17 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
