Can't get Lokar dipstick to fit
Old Dec 5, 2004 | 01:34 AM
Mullet Z28's Avatar
I have splayed four-bolt mains and someone suggested getting to Lokar dipstick since the stock dipstick won't work anymore. I got one, but it the dipstick still won't go all the way down the tube. Sometimes it get stuck 2/3 of the way down and sometimes after only 1/3 of the way down. Please help.
Old Dec 5, 2004 | 06:40 AM
Loadre's Avatar
Re: Can't get Lokar dipstick to fit
Trying twisting the dipstick as you push downward.
Old Dec 5, 2004 | 07:53 AM
n2oCamaro's Avatar
I had to cut a 1/4" off the bottom of the tube to get mine to work. (I have Milodon splayed caps). My tube would not go all the way in the block, nor would the stick go in. After cutting it, the dipstick goes in with a slight twist at the bottom.
Old Dec 5, 2004 | 06:27 PM
Mullet Z28's Avatar
Hmm...twisting doesn't seem to do anything. The tube goes in the block, but the dipstick won't go in the tube.
Old Dec 5, 2004 | 07:33 PM
Hawk's Avatar
I don't get it. Is the tube straight?? if you have the tube IN the block ALL THE WAY the dipstick should slide right in. What exactly is it hitting, are you talking about the head of the dipstick or something jamming up inside the tube??
Maybe u should take out the tube and see if u can slide the dipstick in, make sure nothing is pinched inside or damaged.
Brian
Old Dec 5, 2004 | 09:12 PM
Loadre's Avatar
The dipstick protrudes out past the end of the actual tube. Therefore his actual dipstick is hitting his main cap.
Old Dec 6, 2004 | 10:12 PM
Bud M's Avatar
I have a hard time pushing my Lokar dipstick in sometimes. When that happens you have to kind of turn it as you keep trying to push it in until you get it just right and it pushes all the way in.
jmadoll
May 27, 2015 07:13 PM
Apr 3, 2015 10:54 AM
jmadoll
Mar 3, 2015 10:16 AM
Camaro_Eric
Aug 8, 2002 12:21 PM
rncotton
Jul 1, 2002 10:43 PM
