Intake gasket for a LT4 the same as LT1?
Old Dec 5, 2004 | 10:14 PM
2QUIK6's Avatar
Went to buy an intake gasket set for my LT4 today, and I told them specifically LT4 for a '96 Corvette since that's what car they primarily came in, and the part counter said that they only show 1 part# for that year for a 5.7......could that be right?
Maybe a generic gasket that would fit both an LT4 and LT1...I thought the runners were different sizes.
Old Dec 5, 2004 | 10:23 PM
pntballty's Avatar
Re: Intake gasket for a LT4 the same as LT1?
I wouldnt think it would work but maybe it would, i checked shoebox's site and i couldnt find a LT4 specific intake gasket. http://shbox.com/1/Parts.htm
Tyler
Old Dec 5, 2004 | 10:44 PM
79Lt1T/A's Avatar
intake gaskets are the same..u can make an lt1 an lt4 w/o changing the block or valley runners or anything..
Old Dec 5, 2004 | 10:53 PM
Spinner's Avatar
LT4 should be a taller gasket.
Old Dec 6, 2004 | 01:30 AM
JasonL's Avatar
There should be two intake manifold gaskets for the LT4.
One is the regular replacement.
The other I think is a GMPP replacement that supposedly does not block the ports like the original... known as the "7777" gasket because of the part #.
I would ask the dealer again, and make sure he is looking up the right part. The LT4 VIN engine code is "5", LT1 is "P".
Old Dec 6, 2004 | 04:07 AM
rskrause's Avatar
Moderator
The pn you want is 12367777 for the LT4 heads/intake.
Rich
Old Dec 6, 2004 | 08:30 AM
LT4383's Avatar
LT4-12528884 part no.
LT1-12524653 part no.
Old Dec 6, 2004 | 09:27 AM
2QUIK6's Avatar
Thanks all for the info, I was figuring they'd be a little different since LT4 intakes or heads aren't direct bolt-ons without having both.
Old Dec 6, 2004 | 09:31 AM
rskrause's Avatar
Moderator
Don't get that LT4 pn, get the "7777" gasket.
Rich
Old Dec 6, 2004 | 12:41 PM
Shon Herron's Avatar
Been there done that and have pix....LT1 and LT4 intake gaskets are different.
Did you know that if you use LT1 on the LT4 stuff and it rains that the cylinders can fill with rain water? Now how that much water got on the engine I have no idea but it has happened....
Old Dec 6, 2004 | 01:22 PM
99vette's Avatar
the LT1 and LT4 gaskets are different. When I rebuilt my LT4 I was accidentally sent LT1 intake gaskets. The ports do not match nor do the alignment/rataining pins.
Old Dec 7, 2004 | 12:54 PM
2QUIK6's Avatar
I guess the only place I can get the '7777' or the other LT4 gasket is the dealership. Neither Fel-pro nor Victor have an intake gasket that matches the 2 LT4 part#s given above.
95chwagon
Jan 13, 2015 09:19 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
