Any one using an aftermarket EXTERNAL fuel pump?
Old Dec 3, 2004 | 11:47 AM
1bad98gmc's Avatar
Just wondering if any one here is using an external fuel pump? If so what one, and thoughts? I need something for my project truck!
Old Dec 3, 2004 | 12:44 PM
Re: Any one using an aftermarket EXTERNAL fuel pump?
I run dual Bosch 205LPH pumps, one in the normal in-tank position, and the other external, off a -10AN connection welded to the bottom/back of the tank, with an internal baffle and screen added to the tank. The external pump only runs when the dry nitrous system is armed. Each Bosch pump is good for about 500HP.
Old Dec 3, 2004 | 01:16 PM
944v8inDFW's Avatar
I have been using a Motec / Bosch "blue stripe" on all my transplants. External and about $170 blus shipping. Come with a euro styled check valve. If you need a vendor contact info let me know.
Old Dec 3, 2004 | 01:25 PM
1996LT1NY's Avatar
I've been using Aeromotive #11106 or #11104 depending on the application. I'm working on a 79 Malibu now that the customer bought a Mallory Comp 110FI for... don't know how that one works yet but I've had good luck with the aeromotives.
Old Dec 3, 2004 | 01:45 PM
Zepher's Avatar
I've used the Holley Universal external pump. It's 230lph.
Old Dec 3, 2004 | 08:00 PM
1 Nasty Bird's Avatar
What kinda motor do you need to feed? Ive been very happy with aeromotive products. Big external pumps are LOOOUUUUDDDDD though!!!!!!
cmyname1
Feb 19, 2015 08:38 PM
Scottyboy
Feb 11, 2015 10:28 PM
ANDYZ28
Dec 29, 2014 09:13 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
