alternatives to LT4 ED timing set
Old Nov 30, 2004 | 07:07 PM
dmoor88's Avatar
What are some alternatives to the LT4 ED timing set? I'll be retaining my stock mechanical WP...
Thanks ahead of time!
Old Nov 30, 2004 | 07:11 PM
Paul94Z's Avatar
Re: alternatives to LT4 ED timing set
I pulled up this old thread.. might want to take a quick look at it
http://web.camaross.com/forums/showthread.php?t=278981
Old Nov 30, 2004 | 07:18 PM
dmoor88's Avatar
I've read through that thread considering I posted in it myself. It didn't really include anything that I was looking for. A Cloyes chain was mentioned, but I'm looking for as many alternatives as I can find; which is why I started a post pertaining to such
Old Nov 30, 2004 | 08:16 PM
Paul94Z's Avatar
as far as I know the only option besides the ED set is the cloyes which is virtually identical.. I think someone mention cloyes actually is the OEM for the GM sets. I don't know of any other aftermarket sets that have the pump drive gear face. What I really want to find though is a part number for the cloyes oversized crank gear that they say is better.. and the chain.
Old Nov 30, 2004 | 09:30 PM
dmoor88's Avatar
anyone else?
Old Dec 1, 2004 | 03:11 AM
unTAmedLS1's Avatar
its the same price to get a lt4 ed as it is to get an electric waterpump and cloyes double roller together so thats what I did
Old Dec 1, 2004 | 07:39 AM
grygst76's Avatar
When I did my h/c I used a lunati chain and so far it works pretty good, I didn't want to spring for the LT4 due to the overprice
Old Dec 1, 2004 | 12:54 PM
dmoor88's Avatar
I don't want an elec. WP since I got a refurd stock replacement for $110 with a lifetime warranty. Installed it and now I dont have to worry about changing it out every couple years like Id have to do with an EWP.
Old Dec 1, 2004 | 12:56 PM
dmoor88's Avatar
Happen to have a p/n on that chain? What did you use to replace the gear sprocket?
Old Dec 1, 2004 | 02:27 PM
grygst76's Avatar
No part number off hand but I didn't replace the sprocket cause it was in great shape.. get it thru jegs or summit though.
Old Dec 1, 2004 | 02:40 PM
captain_foustas's Avatar
just a quick warning if you didnt aleady know.
the coyles requires that you remove a mechanical waterpump and use an electric one.
Old Dec 1, 2004 | 02:44 PM
skibbe_96z's Avatar
The summit EWP is rated at 10000 hours...if you drove for a total of 5 hours every day...which is very unlikely..you would hit 10000 hours after 5.5 years. That is pretty good if you ask me. Considering you will prolly drive it 2-3 hours daily and maybe 4-5 hours on the weekend...you are looking at around 7.7 years. Just thought you should know.
I will be going with the cloyes and the EWP when I do my cam swap.
Old Dec 1, 2004 | 02:46 PM
unTAmedLS1's Avatar
Yeah I dont get what everyone is afraid of...I rarely see any posts on electric waterpump problems and if there is a post its usually because someone is bad at wiring or making sure connections are covered
Old Dec 1, 2004 | 03:36 PM
pntballty's Avatar
What did you do about your CPS? Im about to do the same thing and ive heard the CPS can be in the way.
Thanks, Tyler
Old Dec 1, 2004 | 03:37 PM
dmoor88's Avatar
no point in going with an EWP since i just replaced my stock one. plus the cloyes that captain is talking about is the double roller. im looking for something that has provisions for the WP shaft.
