Delteq question
Old Dec 1, 2004 | 03:32 AM
ReD0917's Avatar
Delteq question
Ok my opti is out on my '93 z. And if i go with one of these Delteq system does the opti have to be fully fuctional for it to work? Sorry to ask this question but I still don't see how it'll work with a none fuctional opti. Also is the Delteq sensitive to water or moisture?
Old Dec 1, 2004 | 04:38 AM
GreenDemon's Avatar
Re: Delteq question
Q1: What's dead on your opti? If it's the cap & rotor (causing preignition/detonation), then you can use it. If it's the optical sensor in the back, it needs replaced. The LT1 computer needs the optical sensor for it to make timing adjustments, and if it doesn't get a signal it won't do squat...
Q2: All electronics hate water & moisture. Although I'm pretty sure the Delteq system is fairly well sealed, and shouldn't be more sensitive to water than any other ignition components.
Old Dec 1, 2004 | 05:08 AM
ReD0917's Avatar
Re: Delteq question
dang!how in the world am I going to know what's bad. Guess I'll be looking at the dynaspark. Thanks GreenDemon
Old Dec 1, 2004 | 06:30 PM
captain_foustas's Avatar
Re: Delteq question
whats wrong with the opti? what problem code?? more info and we might be able to figure it out
jasonduaine
Mar 7, 2015 09:44 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
Ari G
Dec 11, 2014 03:21 PM
