Advise needed removing waterpump gasket
Old Dec 3, 2004 | 02:39 PM
97silverz28's Avatar
I'm in the middle of my waterpump project (what a pain in the a**). Before I install the new pump, I'd like some advise on getting the old gasket material off the block. With the block being aluminium I dont want to get to aggresive scraping into it. Any suggestions? Thanx.
Old Dec 3, 2004 | 03:00 PM
1996LT1NY's Avatar
Re: Advise needed removing waterpump gasket
If this is on an LT1 the block is iron........ scrape away
Old Dec 3, 2004 | 03:08 PM
Z28barnett's Avatar
Scotch/3M pads like you use on dishes but heavier grit work good.
They sell little kits at Walmart with the pads that fit in a drill and are about 1 1/2" in diameter.
I tried to use them to clean the heads when I put my headers on. They worked good but hard to get to the sides of the heads. Should be easier on the front of the block.
Z28
Old Dec 3, 2004 | 03:17 PM
Whoops, my bad. I thought the block was Al.
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
lbrowne
Nov 13, 2011 04:25 PM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
