Trying to remove IAC..Stripped the bolt...
Well i stripped lil hex nut bolt thing that holds the IAC to the TB...what now? Should I remove that bottom plate that has like 7 nuts in it, and clean it that way? Will I be able to clean it up that way? I dont have a Gasket for it, so if I tear it I will jes go get one I guess...
Anyway to get out a freaking stripped hex bolt that small?
OK I just removed the bottom park that holds the IAC..and the gasket cumpled lol....do I have to get this from the dealer? ANyone have a part number?
Re: Trying to remove IAC..Stripped the bolt...
You need to drill the head off that bolt, then get it out with some vise grips (maybe an easy-out, but it's small), then get another screw.
-Dave C. '97 Z28
-Dave C. '97 Z28
Chevrolet, Pontiac, or take the good on to a hardware store and maybe get lucky.
I bet the dealer will sell them for about $5.00 to $7.00.
-Dave C. '97 Z28
-Dave C. '97 Z28
pretty much all the small bolts in the TB try to round out the centers on them. I just used vice grips to grab it and break it loose. Then after that i put anti-seize on them all.
NewsBot
Sep 14, 2015 09:20 AM
RX Speed Works
Sep 11, 2015 03:31 PM
