Harmonic Balancer/flexplate... vibrations..
Old Oct 11, 2004 | 07:42 PM
Smokn '94 Z's Avatar
Question Harmonic Balancer/flexplate... vibrations..
Well I am having a fine vibration for the past couple of years on my Z and am just now trying to figure out and locate a fix. I have my trans out and sent my Converter out to get looked at. I visually inspected the flexplate and see no cracks or anything out of the ordinary. The vibration is felt at 2200 - 2800 rpms in any gear and in park which cancels out any drivetrain causes. The vibration is consistant and rythmatic. I can see the rubber in the harmonic balancer starting to dry-rott but not sure if it is significant enough to be the cause. I was going to swap all this out but the Harmonic is pretty expensive. Is there anything I can do to thoroughly inspect the Flexplate and harmonic balancer to determine if either of these is a possible cause? Also where is the best place to get a new harmonic balancer. I know these topics have come up and I did a search but none seem to have the awnser I am looking for.
Old Oct 12, 2004 | 09:53 PM
Lightbulb Re: Harmonic Balancer/flexplate... vibrations..
Well I am going to throw a flexplate on it while I have the trans out... Even if it doesn't help at least I will know..
Jeff1904
Jun 5, 2016 05:00 PM
Daluchman1974
Sep 11, 2015 06:12 AM
Red_94Formula
Mar 7, 2015 09:21 AM
indieaz
Aug 9, 2003 09:17 PM
treyZ28
Advanced Tech
Jun 24, 2003 10:27 PM
