Head/Cam Questions.
Old Oct 9, 2004 | 02:15 AM
Silvershark's Avatar
Head/Cam Questions.
Going with Lloyds head/cam package and I want to make sure I am purchasing everything needed on my end so I can install these upon completion.
ARP 7/16 studs
GM 14011051 guide plates
7.2 Comp High Tech pushrods
Comp Pro Magnum 1.6 ratio 7/16 stud NSA rocker arms
Do I need new lifters as well?
Also, would the 7.2 Comp Energy Tech Pushrods surfice for my goals?
400-420HP N/A 6400rpm shifts...
Old Oct 9, 2004 | 04:24 AM
Flyin_Z28's Avatar
Re: Head/Cam Questions.
Don't forget:
-head bolt kit from ARP
-heavy duty timing chain set, Cloyes TR or Rollmaster (if you ever want to go to an elec. waterpump now is the time)
-lifters are a good idea, comp "R" or crane
-gaskets (might as well get a whole replacement kit)
-7.2 High Energy Tech pushrods should be fine, if you get the heads milled for higher compression you will need shorter ones.
-Injectors 30#, 32# or 36# (stock ones 24# will max out with you goals)
I've found Combination Motorsports a good source of information. If you unsure of anything give them a call, very helpful.
Old Oct 9, 2004 | 07:37 PM
97s10ondubs's Avatar
racetronix fuel pump, i'm getting the LE2 package done as we speak and thats the pump im going with
Old Oct 9, 2004 | 11:07 PM
lt1camaroman93's Avatar
You should hold off on buying pushrods until you get the whole combo together. You need to check you valve train geometry to see what length pushrod to run.
Old Oct 10, 2004 | 02:27 PM
lloyd says to use the 7.2, thats what he told me when i asked him which ones i needed
Old Oct 10, 2004 | 02:47 PM
Yah, Lloyd gave me a run down of what I would need. I was just seeing if it was necessary to get new lifters as well... From what I hear the lifters will just pretty much make my valvetrain sound quite...?
RUENUF
Mar 13, 2016 03:37 PM
69z-28
Jan 29, 2016 10:46 PM
ZXXVIII
Sep 1, 2015 04:14 PM
Aug 28, 2015 07:53 AM
Pestilence
3rd Gen / L98 Engine Tech
Aug 18, 2015 10:16 AM
