loss of power between 60 and 80 kmph
Old Oct 10, 2004 | 01:25 PM
1quickgt's Avatar
just wondering what it could be the car has no power doesnt down shift (its an a4) the car only has 50,000 k's on it also it sututters and hesitates at high rpms time to change the spark plugs perhaps? any ideas would be much apprecated
Old Oct 15, 2004 | 11:15 AM
hotazzz28's Avatar
Re: loss of power between 60 and 80 kmph
I'm having a very similar problem. Couple of weeks ago I start feeling a power loss, the car seems to hesitate when I accelerate from a standing position. I cleaned my air filter & checked for a spark under the hood in case one of the wires was burnt (although its tough to get a good look) and didn't fix or find anything. I think I'm going to redo the Hypertech 3 programming. Post back when you figure out your problem.
Old Oct 15, 2004 | 11:32 AM
ChrisS95TA's Avatar
Also check fuel filter and coil....and scan the car for knock retard when those problems are happening that is a possibility too if you have a miss and it is causing knock, I had knock AFTER plugs, wires, opti, and fuel filer and an LT4KM helped it alot. Good luck
Old Nov 10, 2004 | 10:58 AM
hotazzz28's Avatar
I installed new plugs (all but one) the other day, that corrected the hesitation & rough idle. Then I put in a new PCV valve & that seemed to help restore the car to normal power levels. I'm going to put in a new fuel filter this weekend.
I have to move the header to get the first plug on the passenger side in can anyone tell me if I should pick up a new gasket before I start?
Old Nov 10, 2004 | 12:03 PM
TobyZ28's Avatar
I say change the spark plugs and fuel filter. Then see where your at. Mine would "break up" at higher rpm. Replacing the opti fixed that for me.
warmeck
May 7, 2015 02:10 PM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
thenewkid
Nov 27, 2014 09:41 AM
XtremeLt1
Sep 13, 2002 08:50 PM
slothgrant
Aug 22, 2002 03:01 PM
