Looking for the bolt-on pulley set-up that replaces the power steering pump...?
Old Oct 11, 2004 | 08:49 PM
MattSLONOMO's Avatar
This was so you could run a manual rack but, keep the ac..
I remember seeing this a few years ago..
but can't seem to locate it now..
if anybody can help and lead me to it I'd appreciate it!
Thanks Ahead!
Matt
Old Oct 11, 2004 | 10:17 PM
Jay-Roll's Avatar
Re: Looking for the bolt-on pulley set-up that replaces the power steering pump...?
The only I believe I've ever seen is the bracket that eliminates the AC. There is also another one out there that allows you to drop the alternator to the bottom of the motor to use normal valve covers instead of the passenger side with the little notch in it. Which I think allows you to retain AC, but don't quote me on that. Try PMing Dreamer1q I think he's the one that helped bring the Alt. relocation bracket to the market, me might be able to point you in the right direction.
Old Oct 12, 2004 | 12:46 AM
will69camaro's Avatar
I'd like to know info on this as well. I have an LT1 that is going into my 69 camaro and it's not going to have any power anything, and no a/c. I'm probably just going to rig something up for it but if i can buy deletes for stuff i'll give it a shot, and i like the sound of dropping the alternator down to use regular valvecovers.
William
Old Oct 13, 2004 | 02:44 PM
ttt
Old Oct 13, 2004 | 11:41 PM
JG94Z's Avatar
www.mycamaroz28.homestead.com makes relocation alternator brackets them where you delete PS and AC. You remove the whole accessory bracket and replace it with their part.
If you want to retain PS or AC then this kit wouldn't be for you though.
Old Oct 14, 2004 | 12:51 AM
Thank you i will definitly look into that setup because even when i decide to run a/c and powersteering i need the vette system so this might make due till then
Thanks again,
William
HectorM52
Jul 30, 2017 11:46 AM
Richardan15
May 30, 2015 08:36 AM
